You already said that.
We need to know how much of that capacity your vehicle is already using so that we can figure how much the charger can use.
From what I gather, the way to measure this accurately is to measure the output current of the alternator with the vehicle parked and revving the engine up to 1500-2000 rpm. Then I'll know how much current the alternator already pushes to charge the starter battery, correct?
Another consideration is the max charge current of the 206ah SOK: 50A
If the max current output of the victron 100/30 mppt is 30A, the battery can only accept another 20A so isn't a 30-40A DC-DC charger unnecessary? Or say the charge controller is only putting out 10A due to low sunshine, having a higher Amperage DC-DC charger (say 40A) working safely within the alternator's leftover capacity (what's not being drawn to charge the starter battery) will be more equipped to fulfill the 50A max charging current of the 206ah SOK, right?
Which brings me to a concept I'm still struggling to understand: If the recommended max charge voltage of the 206ah SOK is 14.6V, how is there no conflict between multiple charging sources (panels w/ mppt, DC-DC charger, and inverter/charger)? How do the components safely work concurrently without conflict or damage to the system? In discussing this with my father, I am unable to explain how/why it all works together without issues, I need to understand this concept.
First off multiple charging sources are generally not an issue. Each will have a maximum charging voltage and will stop when that voltage is reached. Having multiple sources will not push the voltage higher than any of the chargers is programmed.
Is this an RV? Van conversion? If you add an inverter and want to connect to the existing 120v system a transfer switch is needed and will select power from the main cord or the inverter. Generally inverter-chargers will have a built in transfer switch. If no inverter is being installed then no transfer switch is needed.
No need to turn off solar or the charger while driving and charging through the DC-DC charger. These all can operate together or separate depending on which have a power source to charge. BMS is the last stand of safety to protect the battery. The various chargers should never trip the BMS even when used together.
How/why?
In
this thread, time2roll comments: "Multiple loads and multiple charging sources are good to all run concurrently. No issues."
Please explain how/why this is? I'm not trying to be dense here, still just a newb trying to understand something totally new to me.
Once again, I want to express my gratitude to everyone taking their time to help me understand!
