Rocket1Point0
- Dec 3, 2022
- 7
I've beat my head on the wall on the following. New to RV electrical upgrades and new to the forum. I have designed and wired data center server racks for a living and have done some household electrical. However, I'm having a heck of a time deciding on a location and configuration for the batteries and inverter on my Forest River Ultra-V 2618VS. Floor plan and specs can be found, here. Storage space is extremely limited and there is no exterior storage compartments except on the bedroom slide:
I am not planning on adding solar at this time. We like to camp in state and federal parks and have discovered a couple in my area that do not have electrical hookups. So, I'm looking to add enough power to cover a 2-3 day campout without connecting to generator or electrical. In testing, 200 ah appears to be sufficient when the heater needs to run at night for two days. 300 ah would be ideal for 3 days, but 200 ah would be sufficient for 2 days and when the heater is not needed.
The power center is a WFCO 8955 under the fridge that does not support lithium. There is only room for one Group 31 battery on the tongue. I'm planning on replacing the WFCO 8955 with a WFCO 8930/50 distribution panel that supports two 120v legs (e.g 50 amp service) and use the first leg for 30a non-critical service and the second leg for inverter distribution. Shore power inlet is at the back of the trailer.
There is limited storage in this trailer and limited places I can find that "might" work. I was hoping to obtain some input from the members to determine the ideal location and any concerns or issues I may not have considered:
If all batteries are relocated inside, the longer brake emergency break away circuit would be a long run to the batteries. Would you recommend a small 10 ah tongue battery for this or is the long run not an issue? This is typically an unfused wire and could become an issue with more chances for damage / shorts along the path.
I'm looking to minimize cost and balance this with automation / ease of use. I may only have this trailer for another 3-5 years and we plan to purchase a 5th wheel when we retire.
Ultimate configuration would allow powering the microwave and outlets in the trailer. A Xantrex XC 2000 appears to be the most economical solution and I would welcome other suggestions. Though I like the power assist features of the Victron products to allow running on a smaller generator for AC use, the Victron Multiplus line is probably more than I want to spend on this trailer.
For batteries, I'm seriously considering Enjoybot's line with their new low-temp protection and SOK batteries if I need a smaller package.
Thanks in advance for your assistance and suggestions!
- In front of the sink for the batteries and behind the power distribution panel under the fridge for the inverter (deck mounted). My only concern with this area is possible leaks with the water lines or plumbing that might cause problems. Custom battery storage will need to be fabricated to cover and protect the terminals. Also, since this is under counter storage for the kitchen, I'll have to find a solution to protect the DC wiring path to the inverter. Most of the area is taken up by the propane tanks outside, but there is 30"w x 9"d x 20"h available space that will still allow access to the plumbing for maintenance. The door opening is 11"w x 27" h.
- Under the dinette seating near the front entry door. The water heater is located in this area and could be a problem if a water line breaks. 20"w x 18.5"d x 16"h. Additional 14"+ of space is available on the left sidel for mounting the inverter. Being on the opposite side of the trailer will be a challenge and if used, I'm considering running flex conduit through the closed underbelly to the other side for the AC and minimum 6 awg for the DC circuits. Challenge would be removing the underbelly covers (screwed and stapled), and working around the existing front grey tank.
- Under the opposite dinette seating area. About the same space without the extra space to the left. Heater is located there so isolating into two compartments to reduce heat will be critical. There is also a cheap subwoofer that would need to be removed or relocated. Same issues with power routing, just longer runs.
