FullMoonSolar
- May 22, 2022
- 11
Hello,
I need some advice and was hoping someone here could help. I currently have a Xantrex 3024 connected to 24VDC AGM batteries. The Xantrex outputs 120VAC to a panel in a boat. I am adding a larger Context XW+ Pro connected to LiFePO4 batteries to generate 240VAC to now un-backed up loads. I have decided to keep the AGM for the life of the battery set at least - maybe longer. Originally I planned to remove the 120VAC from the output and use the LiFePO4 for both 120/240. It occurred to me that maybe I can simply add a load center with the Xantrex connected to a separate breaker and the Schneider connected to a 2P breaker - then run the output of the load center to the boat's panel. On loss of power, both should charge their separate battery sets. Any thoughts on this hair-brained scheme?
Thank you in advance
