Madcaroler
- Dec 11, 2021
- 13
Hello. I have two SPF3000TL units for an emergency power system split-phase configuration. Attached is a picture of the current set up: a sub-panel fed by either generator or grid power. I can't determine where the Growatt units should be placed for this to operate correctly. The simplest solution I can think of is separating the switch and the loads and putting the inverters between the output of the switch and the loads. What do?
