Uncommon specification of capacity. I don't know how to convert that into Ah.
Anyway, based on the dimensions/weight I would guess them at approx 120Ah each.
With 2 in parallel that would be 240Ah. As a general guideline 1/10 capacity is recommended, so in your case a 24A charger.
I would go for a Victron 25A. Victrons are decent, and can be adjusted for other battery types as well, so if you're going to upgrade it's just a matter of changing settings. They aren't cheap however.
Since those Eaton batteries are designed for UPS applications they don't fully match a offgrid/rv setup and I won't be surprised if they dont last very long.
Another option to consider is getting a charger/inverter combi. That might be easier and cheaper than having seperate parts.
