ericfx1984
- Oct 10, 2021
- 763
I ha e the following Aims power inverter
It's capable of 100 amp charging into a 12 volt battery bank
I'm currently running a pair of large lithium batteries that works out to about 22 kilowatt hours
There hasn't been a lot of sun lately so I went ahead and fired the generator today and the inverter auto switched over to charge mode, the display showed that it was charging however when I looked at my battery management systems it was obvious that I wasn't getting any power out of the inverters built in charger
I shut the inverter off and fired it back up and it started charging again for a couple hours... But then stop charging... I went ahead and rebooted the inverter again
I'm thinking at this point it might make sense just to get a separate charger... It's also been insanely cold I don't know if that's got something to do with it? Maybe it's an issue with the built-in transfer switch? I don't know
3000 Watt Pure Sine Inverter Charger - ETL Listed Conforms to UL458 / CSA 22.2 Standards
3000 Watt Pure Sine Inverter Charger - ETL Certified Conforms to UL458 Standards
www.aimscorp.net
