NEWYORKHILLBILLY
- May 12, 2020
- 136
I am kinda new to this so maybe i overlooking something,But i cant seem to find a Bms with low temp shut off that will only shut down charging and let you still draw power to load. I know the battlel born battery will do this. so this must exist
Here is my planed system 280Ah 4s 12 volt battery 500 watt solar victron 100/50 scc. installed in small trailer with wfco 55 amp converter. no inverter at this time.
my other question is there a way to keep power to the MTTP if the bms disconnects ?
would a common port or separate port work better for this system ?
