Regarding 4215bn…
I fought the usb monitor cable and won, and now I have access to the settings from the pc monitoring software. There is a setting box for temps and it shows options for high and low temp cutoffs for charging, I set them where I want them. This isn’t an option you can change in the MT-50, doesn’t anyone know if this works with the 4215bn or if it’s an artifact from a different SCC?
Worst case if nobody knows, I’ll set the limits in a way that I can test it with ice water.
