brandonboosted
- Jul 30, 2021
- 158
I am currently using 2 Victron Multiplus II in a split phase configuration. I have started the workings of being able to back feed my main panel in a power out situation (temporary only). I'm a little over a year into this build and I am almost content with its current state and performance. At first it was just going to be extremely small scale but the more I dug in the more I wanted to scale up the project. That led me to 6.4kw of solar, 42kwh of batteries, and 4.8kw of inverters. Currently this all feeds a dedicated load panel that runs some critical loads and 2 mini splits. I cant really seem to find much information on these inverters being used, they are relatively new, I think they came out in the US around May and I got my hand on a couple right away, at this time I thought 4.8kw would be enough to run what I wanted to run at that time, but I didn't take my surge capacity into equation. My understanding is these are LF inverters and should handle a 2-3x surge, with that being said, has anyone else successfully been able to start their HVAC ac compressor with one of these inverters? I have read some can surge up to 130a and when my clamp meter with inrush shows up ill know for sure what I'm dealing with. I am seeing these LF EG4 and growatt inverters doing it fine and wondering if I should have gone something along the lines of that, I can add 2 more inverters in split phase but that only gets me to about 40A per phase and that would be 120A (x3) for a very small amount of time. Running my hvac is really more of a want than a need, mostly want the ability to run my heat pump if needed, running only pulls like 1000w per leg its all just the startup that I am concerned about. I have tested my 120v air compressor, that is about 44a surge (approx without inrush meter) that seems to be fine. Any help is appreciated, thanks.
