callmeburton
- Mar 4, 2022
- 265
I believe this was installed in Maine or Vermont, I forget which, and I acquired it second hand from the guy who removed it from the dwelling it was installed on. I am trying to identify the manufacture so I can more easily find components I need to put it back in use. I tried to find a valve to install at the compression fitting on these for example and nothing locally would work. A 3/4 compression fitting nut would "work" on the male to male adapter but the reverse wasn't true, the 3/4 threaded valve wouldn't allow the nut on the units to attach to the unit for compression testing.
This will be a drain back setup but I want to check the manifolds for leaks before installing it.
![1703180575192.png 1703180575192.png](https://diysolarforum.com/data/attachments/184/184338-0291152d52d88fe13a7471b0f6c6d901.jpg)
