St34mPunkPrivateer
- Feb 19, 2020
- 16
Has anyone tried this kind of tracking system, its so simple. I will be using it on a boat at anchor so that gonna have other issues, but seems nifty.
In this video, the host discusses vertical shades to ensure better alignment and deal with the morning issue. I have seen a solution that only uses vertical shades. The longer those shades the more accurate the tracking.Has anyone tried this kind of tracking system, its so simple. I will be using it on a boat at anchor so that gonna have other issues, but seems nifty.
Can you find a link to what you are describing? I think I am following but am not sure.In this video, the host discusses vertical shades to ensure better alignment and deal with the morning issue. I have seen a solution that only uses vertical shades. The longer those shades the more accurate the tracking.
Plus with vertical shades you don't need to hide it behind a panel. In fact, one of these, synchronized with all panels, could be used to track many panels or groups of panels.
Finally, putting a detector or panel in this case, facing backward on the eastern-most panel, at not quite 180 degrees from the front facing panel will fully address the issue with tracking back for the morning.
Here you go.Can you find a link to what you are describing? I think I am following but am not sure.
What program?Im wondering if I could run this program off my PC and then route it back to the controller, nothing should be stopping me from doing that, be interesting and might take the need to maintain multiple cpus out of the equation
