Does anyone have any experience with this battery from Walmart?
Ya, it's a good size for the installation I'm working on and the price seems reasonable for the capacity. If I don't hear anything from the forum I might be the guinea pig. Not sure I'll cut it open with a multitool like Will .... maybe.Terminals look nice. It's what's inside that counts. Don't know.
where did you get those numbers it says 20-24 Ah Am I missing something?76.8 watt hours / 12.8 nominal volts = 6 amp hours for $154.95USD.
I presume that you aint using this item / battery for starting an Indian.Ya, it's a good size for the installation I'm working on and the price seems reasonable for the capacity. If I don't hear anything from the forum I might be the guinea pig. Not sure I'll cut it open with a multitool like Will .... maybe.
Not @smoothJoey, but it's on the battery picture lower right corner.where did you get those numbers it says 20-24 Ah Am I missing something?
To the OP what is your use case?
Thanks so does the PbEq mean its equivalent to that size Lead Acid battery. Very misleading And definitely not worth the price.Not @smoothJoey, but it's on the battery picture lower right corner.
I want to build a small battery box for camping. There are many SLA batteries that will work in the space I have, but I'd like to use a small LiFePO4 if I can find one. The 100 -50 ah are to big. I was hoping to find something around 20-35 ah. Any leads?Thanks so does the PbEq mean its equivalent to that size Lead Acid battery. Very misleading And definitely not worth the price.
Leads to items here. They also sell a cheap LFP battery charger which is out of stock right now.I want to build a small battery box for camping. There are many SLA batteries that will work in the space I have, but I'd like to use a small LiFePO4 if I can find one. The 100 -50 ah are to big. I was hoping to find something around 20-35 ah. Any leads?
LiFePO4 Batteries 12V Affordable Lithium Battery | Energized Outdoors
Energized Outdoors has the Longest Lasting Lithium (LiFePO4 Battery) Battery in the industry today per size. If you are looking for a Lithium Ion Battery look no further! Energized Outdoors is the leader in trolling motor, fish finder, flasher, CPAP, Vexilar, Garmin, Marcum, Ham Radio batteries...ampedoutdoors.com
I am not too familiar with the smaller sized cells. But I would imagine they would cost more per Ah than a larger one just due to economies of scale.I want to build a small battery box for camping. There are many SLA batteries that will work in the space I have, but I'd like to use a small LiFePO4 if I can find one. The 100 -50 ah are to big. I was hoping to find something around 20-35 ah. Any leads?
Don't know the company but the fortune batteries have a good rep.I want to build a small battery box for camping. There are many SLA batteries that will work in the space I have, but I'd like to use a small LiFePO4 if I can find one. The 100 -50 ah are to big. I was hoping to find something around 20-35 ah. Any leads?
i bought 6 of these-I want to build a small battery box for camping. There are many SLA batteries that will work in the space I have, but I'd like to use a small LiFePO4 if I can find one. The 100 -50 ah are to big. I was hoping to find something around 20-35 ah. Any leads?
