RF_Burns
FYI, Saw this on my motorhome group on FB. Walmart has Chins 100Ahr LiFePO4 for $266.
Delete this info if not allowed here.
Will has reviewed this battery.Are the pouch cells any good?
This is real consideration to factor in.the only real hope to keep things close to matching
Depends on your goals, the need, your budget.Worthwhile or pass?
Good point!BS don't believe return to store nonsense they won't take it back, "call the 800 number" is what they will tell you, you better check with you local walmart first. The walmarts here in east tx don't even take stuff back form other walmart stores!
Time will tell. I have a 12V 200Ah chinsFor 90 days, I'd get it at Walmart and pay the extra $10. Just not sure it is still worth it since they changed the cell types. Wills recommendation probably does not apply anymore as can be seen in the video above
