For those thinking carports for solar mounting in a few years as these double sided panels get cheaper seems like a good option.
www.purdue.edu
![www.purdue.edu](https://news.uns.purdue.edu/images/2019/alam-triangleLO.jpg)
Solar power from ‘the dark side’ unlocked by a new formula
Most of today’s solar panels capture sunlight and convert it to electricity only from the side facing the sky. If the dark underside of a solar panel could also convert sunlight reflected off the ground, even more electricity might be generated.
