gbeuchel
I am asking this question again because I did not phrase correctly and confused people so here goes.......
I live in Asia and have 220 volt grid (50 hertz) I am NOT looking to create a 120 volt system. I need to use the voltage/hertz here because all the appliances run on that. I do not know if the 2 phases are actually 2 different phases or if it is 2 legs that are somehow out of phase with each other. All I know is that I have 2 legs and a ground but no center tapped neutral.
I want to put together a grid tied system using (I guess) 2 inverters - one for each leg - or is there an inverter than can handle both legs and not require a center tapped neutral. I will have a 48 volt battery system.
The color codes of the wires here are weird and not like the western world. For example, they have a red wire if you are running to a wall switch and yellow if you are running away from a wall switch to something else. The 2 legs are both black and the ground is a different color. It could be any color like white which you would expect on a neutral but, again, we have no neutral here.
Question: Any videos on this kind of set up? What inverters would you suggest? Any comments on feasibility?
