Wait, so my PWM charge controller just wastes the extra volts as heat?What the mppt controller does is takes the excess voltage over your charging voltage and converts it also to amps.
Then I might get a bit more watts from my solar panels if I use a buck convertor to convert the panels 18v output to 14vdc before it gets to the charge controller, which would have the effect of increasing the amps also.
