ATS up in smoke Wife called Fire Brigade out
Neil H
Swindon UK
My own fault I wont go into details but I wired it in wrong
PS yes its chines but what is not made
at lest here in the UK we have to have metal consumer units
I would not fit one of these, internally the link wires are not big enough for the 60A or 100A UK domestic supply regardless of what the writing on the unit or the spec says. Wiring it wrong and releasing the smoke early make be a lucky break.
the main power cables connections and the contacts inside are in fact more heavy duty then my 60amp RCBO
in fact on taking the ATS apart I thought it was very well built
if you were meaning the wires you can see in the photo they are only control wires for switching the unit from grid to backup
No, the braided wires on the ones I have seen when opened up which carry the load. There are lots of makers so at least some are under sizing those wires and not buying two to open one to check.
[..] not buying two to open one to check.
Hm, that's standard procedure for me?! Those are safety relevant devices and by "saving" on the cost of a professional by DIY-ing I'm more than able to afford two of whatever it is I'm going to install - one for analysis to make sure the stuff works as expected.
