ahmad_solar
- Mar 6, 2022
- 13
So I have 14 kwh 48v LiFePo4 battery (DIY, EVE cells + JBD bms), I have another battery of 24v battery (Same, but using 8 cells), is it possible to connect this 24v battery to the main battery using Dc-Dc converter? I know there are some issues here especially that the capacity doesn't match and it will be hard to charge it correctly from the sun (without it draining the main battery).
So is this setup possible?
For context: My inverter is Deye 5kw
I don't mind having the 24v battery provide low power (e.g 100 - 400 w) so it will be only used to assist the main battery and extend it's life when I have high loads or when the sun is not enough
