Kendall_Cox
Need Help Selecting Cord AWG for Setup
ok1 and 3 are over voltage so 2
Any thoughts on AWG for 50ft or 100ft?Page 05:
In addition to the 60-150V limit there is a 20A max input current limit, thus any more than two strings of those panels in parallel will be wasted as 2P is essentially 5% above the limit, and the panels will experience a 5% performance penalty in peak PV conditions.
Please help me understand, I get the 150V and the 20Amp... What I dont get is if those are the limits... then how is the unit rated for 2000W of Solar Input? I have 2 Mangos and 4 400w panels so I guess Ill be charging them simultaneously... what bothers me is how Indiana will never get max performance out of a solar panel. An
Limit?Page 05:
Voc is a hard limit you do not go over and leave a cushion for, unless you want to risk the magic smoke escaping.Help a Newby out... 4pannels at 39V=156V The Mango accepts 150. Surely there is some loss... So how is this Over Voltage? Also should I guess you dont have any input on the AWG for a 50foot cord?
VOC?Voc is a hard limit you do not go over and leave a cushion for, unless you want to risk the magic smoke escaping.
There is loss on the wire over distance, but there is also gain on Voc at cold temperatures.
The wire gauge depends on the voltage and current at x distance.
In your case 10 awg should be fine, even 12 would probably be good but you need to determine your panel setup and then plug your numbers into a voltage drop calculator.
Voltage Open Circuit. (the max they will produce with no load).VOC? I am new... Im sorry I need this dumbed down.
