timselectric
- Feb 5, 2022
- 20,094
All that you have to do is produce more than you use, on most days.
This week, that's not happening for me.
Jesus, how many charge controllers do you have?
Just 3 at the moment.Jesus, how many charge controllers do you have?
Not enough, yet.That’s a lot of panels.
76.8 kwh so far.You’ve got a big battery there also.
What is kw rating?
My DC system is all on one cheap MPPT controller. I may get a second and see if it works better. Also tempting to compare a Victron to my BougeRV one. The price is actually reasonable now, I would have gotten the Victron if it was this cheap last year.Just 3 at the moment.
Not enough, yet.
76.8 kwh so far.
Also not enough, yet.
It only gets better from there ?December 21st
I hope this year the 21st is a good day.It only gets better from there ?
That’s what I was thinking this year.Each year I do better.
Hopefully next year will be the win.
Me too. lolThat’s what I was thinking this year.
Why does TOU kick in for grid charge at 80%SOC?It was pretty dark today and PV was zip. Solar assistant had triggered a charge during off peak. I’ve got at least three days ride through if the grid and sun don’t help but I got a generator that can bring it back to full in six hours if the first two sources fail.
Yea that’s one of the reasons I got the biggest panels I could to limit space.I currently have 51 panels for the 14.5kw array and I get between 350kwh and 550kwh of useable power in Decembers over the last 5 years.
I'd have to do at least 200panels (4 x 350kwh) to run the house on all electric and a much large battery as it can literally be 5-7 days in a row of very limited PV.
I can only repeat.... 200 panels? - AGHHHHHH - don't have room for even 100 panels - AGHHHHHH!!!
January wasn’t to bad for us last year.Well the good news is in 19 more days the days start getting longer each day…
plus the angle of the sun improves each day…..
as the old Merle song said.
“ If we make it through December” …
” things gonna be alright I know.”
You running the entire house on 36kw?My DC system is all on one cheap MPPT controller. I may get a second and see if it works better. Also tempting to compare a Victron to my BougeRV one. The price is actually reasonable now, I would have gotten the Victron if it was this cheap last year.
You can never have too many solar panels. I am just running out of room to put them.
My battery is ONLY 36 KWHs. It's "enough" as long as I only have one really bad day, or two partly cloudy days, in a row. It can cover that just fine, but a second real bad day, and I am going to drop to grid power. When that happens, I typically force some grid charge at the cheap rate still so I can run off battery through the peak rate time, even with little to no sun.
I gotcha..My winter time setting. I simply move both ends of the red line up for darker skiesView attachment 180897
I made 9.7 and used 60.Today I made 16.2 kwh and used 22.4 kwh.
So, I had to use 6.2 kwh from the grid.
December sucks.
Oh damn. ?. Well fish are good for mood stability.It would be even lower if my sons tropical fish died
