chateau_nomad
I have two 100Ah SOK batteries (heaters/low temp cutoff) in parallel in my motorhome, and plan to add a third. I am charging from 600 watts of rooftop solar. The cells in each individual battery appear decently balanced, and have remained so since my April 2023 install. The issue I'm having is often one battery reaches 100% (according to ABC-BMS) and the other only reaches 45% - 75% or so. This occurred randomly all summer long with both batteries occasionally reaching 100% SOC.
Before installing, both batteries were 100% SOC.
The batteries are in parallel connected to a Victron Lynx Power In busbar, which I converted to use fuses. All battery cables (2/0 AWG) are exactly equal length and size.
Positive battery #1 to positive battery #2.
Negative battery #1 to negative battery #2.
Positive battery #1 to Lynx bus.
Negative battery #2 to Lynx bus.
Is there something in my wiring - or something else - that could cause this?
