I read that lifepo4 should not be charged too often to 100%. What would be the safe float charge for these batteries? 55.2vdc divided by four is 13.8vdc which is 100% charge.
I use this for my 4S batteries. Holding here for 20 minutes to an hour helps get a good saturated charge.
For float, it depends on your use pattern. If using batteries full time or nearly everyday, a higher state of readiness at 13.6V is often used. Otherwise 13.4V popular. For my RV in the driveway way too often, i set to 13.2V until just before a trip, then 13.4.
You should not have equalization turned on for LiFePO4.
Set the equalization time to 0 minutes if you can.
Otherwise set the eq voltage to float or boost voltage (i don't know which, sorry).
