Mcstiggens
Greetings all,
I have just begun my new boon dock life in my travel trailer. I am in the process of upgrading the solar system on the trailer since it comes from the factory with only one tender battery and one 165w panel to charge it. In the interest of time and the need to power everything sufficiently (and having no time to dive into the complete install yet) I simply purchased two 200AH LifePO4 batteries, wired in parallel to power everything I need. Only lights, 12V fridge and furnace at night.
The first couple of nights were a breeze and the batteries emerged the next morning with barely any depletion of charge whatsoever, as it should be with that much battery.
In the day I would run a charger that was connected to a separate portable solar generator that I built. A simple top-up and I was doing just fine.
Just before bedtime last night, I ran the genny to blast the heat and top up the batts for good measure. They were at 12.8V at this point and 13.1V after I shut off the genny)
Cut to this morning; I woke up to flashing lights on my furnace thermostat alerting me to "low battery" state. So I go look on my mission control interface and sure enough, it shows batteries as "low".
So I go out and test the batteries with a multimeter and they test at around 10V.
Panicked, I fired up the genny and started charging them. About an hour in, I test the batts and they are back up to 13V
I ran the genny for 3 hours this morning and after I shut it down, the batts were 13V+.
The temps were around 29-30F last night. Not too cold for these batts as far as I know.
Something seems up. They should have no issue whatsoever running my rig overnight and should emerge with power to spare. Also, if the truly were depleted like that, it should take 6 to 8 hours to reach a full state of charge I think.
Could it be a BMS issue? The batteries are Li Time brand BTW. They have good customer support but I am waiting to hear what they have to say about it.
Thanks for any ideas you might have on this.
Mcstiggs
Mcstiggs
