Hi,
I have a motorhome (RV).
It currently has a single solar panel on the roof. I have looked all over it and cannot find any labels showing the power.
The controller is confusing and seems only to show the battery voltage.
That panel is at least 10 years old. It connects directly to the leisure battery.
As it is a motorhome there are 2 batteries, leisure and starter.
I am buying 3 more solar panels - flexible so I can stick them over the cab bed.
Solar specs for new panels
max power 130w
max v 23.08
max current 5.88a
My original plan is to - connect one solar panel to the starter battery through a controller just to make sure that is charged up separately.
Then have 2 of the new solars in series and the existing one in parallel and connect all to an mppt solar controller.
However - controllers seem to want all the solar panels to be the same type.
Should I just leave the existing one as it is and add the 2 new panels as a separate system?
Or should I just mix them up anyway?
Also, i've seen some dual battery controllers - an even better solution would be to have just one controller for the whole lot.
I want to avoid having huge cables going to the battery.
Any ideas / pointers?
Thanks
Simon
max power 130w
max v 23.08
max current 5.88a
Thanks
Simon
