Clifty Branch Farm
- Nov 28, 2019
- 34
I may need to re-educate myself. What charges a battery? Amps or Volts? I was taught and have believed for 40 years that it is amps. I am using AGM batteries. Thanks
Its like asking what fills a water tank? Water pressure or the size of the pipe...What charges a battery? Amps or Volts?
SOURCE: http://www.newelectric.com/whats-the-difference-between-amps-volts-and-watts/QUICK TIP — What’s the difference between Amps, Volts and Watts?
We get the question, “What’s the difference between amps, volts and watts?” enough that we thought we would address it here. There are some fairly complicated answers to this question but we thought we’d try to simplify the answer by using an analogy.
If we think of electricity as water flowing through a pipe it can help us understand amps, volts and watts. Amps would be the volume of water flowing through the pipe. The water pressure would be the voltage. Watts would be the power (volts x amps) the water could provide (think back to the old days when water was used to power mills). So with this analogy in mind the definitions below for amp, volt and watt should be easier to understand:
Amp – an ampere is the unit for measuring electricity. The accepted standard unit used for measuring how fast an electric current flows is an example of an ampere.
Volt – the basic unit of electromotive force in the SI and MKS systems, equal to the electromotive force, or difference in potential, that causes a current of one ampere to flow through a conductor having a resistance of one ohm.
Watt – the basic unit of electric, mechanical, or thermal power in the SI and MKS systems, equal to one joule per second or 10 ergs per second (of a horsepower): for electric power it is equal to one volt-ampere.
Back to our analogy; electricity is the flow (like water) of electrons through a conductor like a wire. The rate at which electricity flows is measured as an electric current. The electric current is measured in amps. What makes the current flow? In our water analogy we could say a battery would be the pump that makes the water flow which creates pressure in the pipe. The pressure is the voltage. And as we said before the watts are the power the water could provide (like to a mill wheel). The watt is a measure of how much power is released each second.
We hope you now have a better understanding of the difference between amps, volts and watts.
So what is your answer then? Amps? or Volts? or Watts?
Current is the measure of the flow of electrons, like count them. Without current flow, no work, no charging is done. Voltage difference caused the current to flow, but no flow, no charge.
