Bowlegs868
Hi
New guy here.
I seem to be having battery problems. I started with 6 batteries at first now I'm down now a new set of 4.
A couple days ago, my charge controller screen started behaving erratic... voltage readings were bouncing all over, warnings popping up on screen etc. After checking them with my multimeter, 2 of the 4 batteries (one from each series) were way lower than the other two. I don't think they were installed with different voltage levels because the installer took them home to charge/balance all four batteries.
I've also had the same problem with the previous set of batteries.
Could anyone give me some answers as to what can be the cause for this? Why one battery in the series drops so low if they started out at the same level?
Charge controller: Epever VS6048AU
Battery: Eaton PWHR12390W4FR (wired in series-parallel)
Inverter: Kayal KYNB-C2000-124CD
New guy here.
