Current setup:
6- 320w panels. Wired in 3s2p. 120voc 20a
1- 206ah SOK 12v battery. Max 50a charge rate
1- Victron lynx distributor
1- 150v/100a Victron charge controller
1- 12/1200 Victron inverter
My question:
I have the MPPT limited to 50a charge due to the battery charge rate limits. My battery is full and in float by 10am. When my load exceeds 50a and I have the solar to cover up 100a will the power still be directed through the MPPT to the inverter? Or will the max load from solar still be limited to 50a? Say I turn on a small portable AC unit that pulls 80-100amps. Will the power be drawn from the battery and the solar will just charge the battery at a 50a rate eventually draining the battery?
My question:
