Responding to Sam, Yesterday I disconnected the solar panels from PMW and checked batteries voltage with the voltmeter. Their voltage was 11.85; this morning was 11.79 volts but PMW shows batteries at 12 volts. At this time each solar panels are connected individually to a different PMW, and both PMW are connected to the same battery bank. PMW 1 shows batteries at 12 volts, PMW 2 (the blue one) at 12.6 volts and the voltimeter shows batteries at 11.76 volts each one. Tonight I will disconnect PMW to see if the problem comes from PMW or the batteries. Is the drop in voltage as I explained before, normal?SamG340 said:
Try removing all connections from the battery, see if they still discharge
It is possible your small pwm charge controller is leaching power over night
If they still loose any significant a voltage over they may be bad batteries
