I have an 8S 24V 280Ah DIY battery in parallel with 3 x 24V 200AH LIFEPOER4 batteries from Signature Solar (22 kWh total capacity) and I have had no issues operating them in parallel for my home backup solar project. Just understand that the SOCs of the batteries will vary over the full SOC cycle by up to 10% in the middle of the SOC range. But by the time you get to the top/bottom ends of the SOC cycle, the batteries will migrate back to similar SOCs. Just make sure that all the batteries are attached and properly torqued to a common bus and not daisy chained. See my 6 slot rack mounted build in the attached picture. The three bottom slots are used by the 3 LIFEPOWER4 batteries. The two slots above that are used by my 280AH DIY battery and I use the top slot to mount a large DC circuit breaker (2x200A) on the output of the positive bus, a shunt on the output of the negative bus for the entire battery bank, a Victron BMV-712 display and a 12V output (thru a 24V-12V step down DC-DC converter) for charging devices. I use 2x1/0 AWG cables for both the positive and negative leads coming out of the cabinet with two 175A Anderson Connectors (350A capability with two cables in each connector) feeding a Victron Power In busbar on the wall. It's working well for my use case.
