simjoc
- Aug 23, 2020
- 12
Hello,
I have a problem with my camper, and I hope there are people who can help me think through it.
Currently, I have the following system:
2p4s 12V 560A (8x Eve 280)
Batrium BMS
No heating pads (yet)
This system is still under construction and was used this summer. I haven't used the camper since, and I disconnected all low-voltage systems for the winter. The battery was still 90% charged when I turned everything off. All power was disconnected, except for the Batrium BMS, which I left on. The temperature here has been around 5 degrees Celsius (41 Fahrenheit) in the past few days.
I used a small amount of power briefly, but it was no more than 1 or 2 Ah.
Now, the BMS is in a Critical Battery Fault state, and undervoltage has been detected. I measured, and one series is at 7.6 volts, and the other is at 6.8 volts. When I log into the Batrium BMS, it doesn't display anything, but the last known percentage was still 90% full. Some cells are at 1.2V, and others at 2.0V.
The temperature has not been lower than 5 degrees Celsius.The battery has not been charged, neither by the vehicle nor by solar. What could have happened here? And what is the wise thing to do now? The period during which the batteries did nothing is about a month, and I can't imagine that so much power has leaked away.
Merry Christmas, and I hope people can help me think through this ?
Batrium BMS
