If its some other chemistry than LFP, I would not have it in my living space.Ooh no it does not it also only have 7 cells. I then emailed Hubble as the casing looks the same and they also confirmed that the batteries only have 7 cells...
If those are LFP cells you are grossly over-charging them.
IMO you are focusing on the wrong thing.Then my question still remains the same why does the % drop almost everytime we have loadshedding from 100% down to 89% in less than 3 weeks. I blamed the battery then got a new one and now it's doing the same
Knowing which cells you have will help us to address the SOC% problem.
lithium ion is an umbrella term that includes LFP.
That is a very strange company policy.I asked Hubble if this battery is a LifePO4 and they confirmed that it is a life po4 battery they were not able to tell me why they only have 7 cells and not 8 as the guy said it goes against the company policy.
Hi.Hi yes I contacted the supplier that import these batteries to South Africa and he told me the battery needed an upgrade he did send me a link to upgrade it myself but I did not have the correct cables to connect the battery to my laptop.
The guy then offered to upgrade the software if I bring the battery in. Luckily his shop was only an hour drive from where I stay. He then also struggled to connect the battery to his laptop then offered me a new battery.
Got home installed the battery and it was on 100% at 26.5v my inverter settings was set to charge to 28.2v and so it did.
But now after a few loadsheddings the battery is doing the same.. It now idles at 89% and I'm sure with the next loadshedding it's going to ilde on 88% so I think it might be the inverter....
When I set the inverter to charge the battery to a higher voltage then you can see the battery charging again but after a few days the persentage drops again...
