Bluenoser316
This is my 1st post here.
I purchased a 100Ah Li Time lifep04 mini battery and am building a power box to use as a ham radio backup (run my ham radios from it daily instead of wall power), and maybe to run a few household things diring power outages, and I am charging this battery with the supplied Li Time 10A AC wall charger manually as I have no solar yet due to living constraints.
Forgive me for asking a totally basic question, but I have been trying to get a straight forward answer about when to recharge this battery for awhile now. Maybe I'm just not asking correctly, because either the question is avoided, or im told to ask LiTime (which i have repetitively) , or, I get a page and a half answer about the state of charge, a bunch of technical jargon ect ect, and still the answer isn't given.
I just want to know at what point when I run the battery down do I recharge it again. What point do I not go below?
It seems like a simple question, isn't it??
I have a renogy battery monitor, and I asked Li Time what settings to put into the monitor, and they replied with the following, but still didn't tell me when to actually recharge the battery after several times asking them, grrrr.
Renogy battery monitor settings:
-Capacity - 100Ah
-Full - 13.33v
-Zero V - 10.8v
-PowerOff - 10.8v (Li Time then told me switch it to 12v just to be safe)
-Alarm - 5Ah
-Atten - 0.2%
So, I entered these values into the battery monitor settings, but, i still do not know when to be triggered to plug in my charger and recharge my battery.
Do i recharge it when it hits 12.2v as I seen on a Will Prouse video? Will said never go below 12.2v.
Do i recharge it at 12v, as Li Time told me to enter 12v as an alarm?
Do i ignore the voltage and recharge it after it hits a certain Ah or percent charge left on my battery monitor, as someone else told me reading voltages was "old school" and no longer valid these days?
It seems like a simple answer to a simple question, yet, I can't seem to get a straight answer.
A straight answer would sound something like this for example: " yes, when the battery voltage drops to 12.2v, that is when you should recharge the battery to 100%, dont let it fall below 12.2v". Lol.
This is the info I'm after, of course I made that up, but you get the idea.
I hope someone here can help me with this, because as you probably noticed, I'm getting a bit frustrated. I'm happy to spend all the time in the world learning lifep04 battery theory, the how and why I should charge it ect ect, but first I just want to get into a routine of charging, using and recharging the battery, and need the basic parameters to do this!
Thanks in advance for your assistance.
-Capacity - 100Ah
-Full - 13.33v
-Zero V - 10.8v
-Alarm - 5Ah
-Atten - 0.2%
