I've used Optimas in various formats and have never had those problems, and even today use them for solar at times because I can hammer them being pure-lead.
While I don't discount anyone's experience, after decades of using them, some of my associates who have problems bring them to me. What I've found from some of my friends who don't really care about batteries in general are:
1) They aren't the original owner
2) They wanted to scam the warranty / free Optima for life club by purposely using the wrong type (red starter when they really needed yellow or blue)
3) The semi discharged battery from the store was simply swapped in the parking lot or at home, without *EVER* getting a full charge. That's really important to charge it fully when you first get it. But they just put it in the vehicle and did nothing but short trips.
4) Fell victim to cheaters cleaning and selling used beaters to look like new from the back of some guys van down by the river. And then scream about Optima not honoring a warantee to a non original owner.
These are the types of things that shorten the warranty.
That being said, here are some fun facts for anyone wanting to use one for solar:
1 - Said before. Charge it FULLY before first use. Saves a lot of pain down the road. Helps ensure you can revive it if you kill it.
2 - All Optimas are basically built the same internally except for terminal arrangements. Some have side terminals, some don't depending on your application.
3 - Optimas in a BLACK cases are SLI (Starter, Lights, Ignition). Not what you want for power storage / solar.
4 - What determines whether it is an SLI or the so-called deep-cycle is how acidic the electrolyte is. Red-tops (and one series of blue tops with the black case) have a higher concentration of acid than the other gray-cased versions, like the Yellow or Blue tops.
5 - So what's the deal with Yellow and Blue tops? NOTHING, except for terminal connections. Like Yellows sometimes having side terminals, whereas the Blues have additional wing-nuts for connecting things like fish-finders, radios, etc.
6 - Just be aware that there is ONE Blue-Top with a black-case to act as a starter for your race-boat. Again, this one is not desirable for solar storage.
WARNING: Some using a parallel connection of Blue-Tops may try to do so using only the wing-nut connections! DO NOT USE THE WINGNUTS for paralleling them, or making your major solar connections to them! Only light-duty connections go to the blue-top's wingnut.
Did I mention to properly charge it before putting it into use the first time? Yes.
I've had great luck using Optimas in both vehicles and solar, but sure there are always exceptions. Then again, I've read through a lot of FUD about Optimas for decades, typically in 4WD forums, so I'm not unfamiliar with all those angry posts about nationalism, not being the original owner, undiagnosed parasitic loads, shortened warranty's and the like.
I've also run Odyssey's. Excellent. Some of my buddies who tried to scam them like they did to Optima got told where to shove it.
So no doubt these things happen. I'm just lucky I guess.
