Battery help!
22slow
Hello, I have a 1.2k off grid system I use for back up. I have 16 280ah lifepo4 batts. I charge them with a Victron 150/35 smart charger. I use a Daly 200 amp smart bms. Here’s the question, as soon as my charger goes into absorbing, one cell tends to run away. The 15 average is 3.4 (I run 90%) but the 16 hits 3.5. when the charger drops into bulk they level out quickly. So tips , tricks, or am I fine? Thanks all
Your battery is imbalanced. Did you top balance them prior to deploying them?
Raise cell cut off to 3.65V
Lower absorption voltage by 0.1V until the BMS stops tripping.
Raise float to 3.45V/cell
Enable balancing only above 3.40V, 20mV difference and only during charge.
Run it like that for a week.
See if you can increase the absorption voltage without tripping the BMS.
Charging to % based on voltage is folly. It's not possible without lots of trial and error. Even then, it's not consistent.
This only happens during adsorption, under load and during bulk charge it evens outD505E09B-7E15-47A0-BC13-346D7FB55CDD.jpeg
Either:
A. Top Balance them (requires disassembling, reassembling, disassembling, reassembling); OR
B. Use an Active Balancer and slow charge for a few days; OR
C. Manually discharge #16, by paralleling a 100W 0.5Ω~1.0Ω resistor to it until within 0.05V of the rest.
B & C should be done without discharging or you will unbalance them
During load and bulk, it is in the "very flat voltage curve". Only when the cells are in the >90% SOC and <20% will you see it deviates alot.
Either:
Really appreciate the advice. One thought though, shouldon’t the bms balance that out?
