Battery isolator functionality question
Firstascent
I have a question about battery isolators I haven’t been able to find an answer on. I understand it’s purpose and function under normal use/wiring, but I’m wondering if there is any functional difference to my simple wiring schematics below.
from what I can see, batteries would still be isolated and everything would function the same way. From the alternators perspective, it doesn’t know the difference.
am I missing something, or would you agree these are functionally the same?
When the alternator isn’t running the battery becomes the power source supplying power to the input and any draw on battery 1 will pull battery 2 down
Oh yeah, duh :) I don’t know why I didn’t think that battery 2 would then become the source and they’d no longer be isolated.
It’s so obvious once I read your post haha, thanks!
I did what your suggesting with a solenoid isolator. I connected the house battery to the alternator to get every last possible erg of energy into the battery. The engine battery was happy at a lesser charge.
Thanks! Most solenoid isolators keep them disconnected until the engine is running then it connects them (ie via accessory signal or similar).
I want the batteries to stay isolated 100% of the time but to both charge from the alternator.
My original thought process of tying one battery to stay directly connected to the alternator is that the Victron isolator I was looking at has a max output of 200a, my alternator is a 280a so I didn’t want to limit the current.
