You'll get a 400 ah 12 volt bank with 200 ah useable.
So if each battery is 200ah and i link them like we have said why do i only get 400ah when i have 4 batterys ?
4 in parallel gives 800ah @ 6 volts. 4800 watt hours or 4.8 kwh.Thanks for the reply i get it now so yeah i the battery i have are 6v 200ah but the 200ah is at the 6v if you make it 12v by the link of series it stays at 200ah not double the only way to make the ah double was link the 2 batts parallel but this would only give 6v
I had eluded to it a couple posts ago.Can't believe I haven't blathered about it yet, but you can always normalize to Wh to make storage independent of voltage.
If you have 6V 200Ah, that's 6 * 200 = 1200Wh of storage. It doesn't matter how you arrange them. Each 6V will add 1200Wh of storage.
If you put 4 in series for 24V, that's still 4 * 1200Wh = 4800Wh of storage. If you want to know Ah, divide by voltage, 4800Wh / 24V = 200Ah.
