kbrawlz
I’m trying not to overthink this, but also not underthink it.
I have some used Trina 250w panels (TSM-250PA05.18). My understanding is that they only put out about 75% of their rated specs.
Vmp: 30.3v
Imp: 8.27a
Voc: 37.6
I want to pick out the correct charge controller or grid tie inverter, but if I account for the diminished output, it falls out of range for the min/max on some most of the units specs.
I plan on using one panel for a 12v system (2 parallel 100ah LiFePo sealed drop-ins). If there is room, I will add a same 2nd panel, but real estate is slim.
I have to imagine that I can just pair it to the specs on the used panel and disregard the lower numbers it puts out, because after all, the panels don’t put out 100% all day and I’d imagine charge controllers still put out some juice even first thing in the morning.
But I’d like someone to give me their input on how serious I should be trying to match the numbers. I obviously don’t want to over voltage/current a unit, but how much can I under power it?
The easy answer is to buy smaller new panels and size it accordingly, but if I’ve learned anything from Will’s videos, you can bend some rules and hodge-podge things together.
I’m out of town very often and once I order something, it’s mine. I don’t get to it in time to send it back if I ordered in error.
So I’m having to make choices without being able to mount and test them on a regular basis.
I’m not necessarily asking for a solution to my problem, just asking what I can get away with in terms of pairing units in the system.
I wanted to either get that EpEver 40a 4215BN that Will recommends OR a Victron 100/30 SmartSolar
I’m trying to pick something that will let me run either 1 or 2 of those Trina panels and the flexibility to go parallel or series to make it work for the controller.
Sorry it’s long-winded. Hope I put in enough details.
Vmp: 30.3v
Imp: 8.27a
Voc: 37.6
