KevinC_63559
I know that when one runs batteries in series, like for a 48V system, the batteries should be 100% matches in terms of vendor, capacity, and age.
I'm unclear on what the rules are for parallel strings (presuming each string is matched). For instance, can I start with 100amp batteries and later add a 2nd-8th string of 285 amp batteries? Obviously the 100amp ones would deep cycle more often. Is that a huge issue or when I upgrade to higher amperage batteries should I search for a new usage for the old 100amp ones?
