Mickie
- Feb 24, 2022
- 213
I bought a battery monitor as seen in the attached picture. I think the configuration is correct but for some reason the AH keeps going up ad it charges its as if its reading amp hours coming in from the charge controller. As my battery back is 200ah at 24v but ah on the shunt is now showing over 400. Would it make a difference if i removed the shunt from the same negative terminal as the charge controller and put it on a different negative?
