sunshine_eggo
Happy Breffast!
Yes I'm getting my battery readings from the charge controllers. Good to know! I thought I could rely on "renogy's" charge controllers for that.
Renogy's charge controllers have no idea how much is going out of the batteries. It only has voltage to go on, and voltage is only reliable in very specific cases.
I'll invest in some actual battery monitors.
Good. Will lists a few on his website. Stick with the top two options.
I don't think I'm using more than what my solar panels are providing.
You're very likely wrong unless you're using heavy loads at sundown. 11.7-12.3V @ sundown is a VERY low state of charge.
At peak sun hours I get anywhere between 750-900W from them and the batteries are usually at "100%" even when my AC is on.
Again, 100% is based purely on voltage, and for lead-acid. it's very easy to get a LFP battery voltage high enough to report "100%" but getting them to 100%.
My AC pulls about 90W.
What A/C unit pulls 90W? Did you mean 900W? Very small 5000BTU window units pull 400W+
I live in the High Desert of CA, the sky is almost always clear with scorching sun.
Happened again! Around sunset yesterday I had about 13V at "90%" and woke up to dead batteries :/
You're not collecting enough sun for your loads. 13V under light load is still likely a low state of charge.
What are the highest typical voltages you see at the battery?
