Thank you. Great feedback. I appreciate it.
The 820 watts was read off of the output of my inverter. And I do know my device was commanding 6-7 amps at 120v.
I guess I am assuming the battery is balanced, it is a brand new, unused battery. I charged it with my solar after install and the charge controller put about 900 watt h in to it before showing the battery at 14.6 volts and charging was reduced to trickle.
The battery does not have communication.
So the battery at bms shut off with load removed showed 12.5 volts. So that should be near full discharge correct? So using my renogy app the next few days I can track how many Ah/Wh are put in to the battery. If that number is not close to the battery rated 120 Ah/ 1500wh it would indicate a battery issue?
I did not notice any heat or abnormal behavior in my set up.
Gotcha. I have 3 of the cheaper pre-built 12v lifepo4s with no bms communication as well, so no judgment there. With the inverter showing 820w and nothing getting hot that number is in the ballpark, it just doesn't include the efficiency losses of the inverter or wiring, but you're still probably talking <900w including those.
So that leaves a battery issue. Taking 900wh to hit 14.6, by itself, doesn't suggest anything bad yet, but it doesn't include the starting point. If the starting voltage before that charge was down in the 12s (or lower!) that would suggest that the ~900wh was almost the total capacity of the battery, which WOULD be bad news. This is just because 12v lifepo4 has already used most of its capacity before it drops from the 13s to the 12s so charging from 12s to 14.6 and only taking 900wh would suggest that's basically all there is.
Most 12v lifepo4 bms will come with a pre-set low voltage shutoff point of 10.0 or 10.5v. BUT, they will also disconnect when any
individual cell hits too low of a voltage, or if there is a high temp problem. The fact that the voltage was already 12.5 after it reconnected is a bad sign because it means either A. a single cell hit too low of a voltage while others were still holding a lot of charge, or B. something in there is getting way too hot. Usually a bad cell is a bit of both because it will have higher internal resistance which means it will get hotter while doing less.
The temp thing would be somewhat easy to rule out because if you can pull a high load on it again and happen to be near it when it disconnects you could just feel around for temp on the case as anything hot enough to shut it down on the inside would probably make it at least warm somewhere on the outside. Could always have a faulty temp switch or BMS built in.. THAT would be inconvenient because it would be hard to diagnose or prove without getting inside and it's probably a sealed unit.
So i'm guessing the more likely thing is it has some kind of cell issue. Without being able to communicate with the bms OR being able to open the case at all, it's difficult to diagnose it any further than that. I would try charging it again, draining it until it disconnects again, look at the numbers, look at the heat, and if it hasn't stayed cool and gotten pretty close to what it says it will do in Wh, i would try to get it warrantied.
If that turns out to be the case it's a point in favor of either or both A. get a bms with communication and B. get a bolted-together case which can be opened for user diagnosis and repair. Both option drive the cost up, and like i said i've bought sealed non-communicating units 3 times so it's not like im saying do what i say, not what i do. But in my case ive been lucky enough to see pretty much the full capacity from my cheap pre-built batteries and haven't had any issues. Still, in all likelihood any future lifepo4 i buy will likely be DIY or at least user-serviceable designs.
