Rapidrob
38120S cell in a pack of four for 12 VDC under load. The battery is new as of January 2024 and was fully charged. I went to use it today and the battery pack was reading 6 VDC. I took a reading of the four cells and found the new battery was only showing 2 VDC. ( should be 3.3 )
When I hooked the pack up to my AIR-8 charger the battery number two shows no voltage. And the charger will error out after a minute of so. The error is " this function is not supported"
Is the cell dead or can it be revived? There were no loads put onto the pack and it was sitting with a BMS hooked up waiting to be used to power a radio.
Did the battery fail and cause this or did the BMS cause this to happen?
