EliteSolar
- Sep 22, 2020
- 90
Guys I'm impressed.
I mean I knew this could happen but not with all-in-one system!
Apparently this allinone system can share power with grid AND run batteryless if you choose so!
I am an amateur/newbie so please excuse me if this common but I have been asking the companies in my country for something like this and everyone said this is almost impossible without complex setup.
It shows that it the power load can exceed the solar power then it will draw the rest from AC.
This means that I dont need to buy any batteries because night time kwhr is very cheap!
I can build 10x325w setup 3250w for less than 2k!
So has anyone used this controllers ? do you know any other controllers that can do the same ? apparently many models are made like this ( similar box ) and very similar characteristics... do the other also support those functions .. ?
Thank you experts!
EliteSolar
5.5kw Solar Inverter Support 5500w Solar Power Run Without Battery 100a Mppt Charger 48v 230vac/5500w Infini Power Inverters For - Buy 5.5kw Solar Inverter,5500w Infini Power Inverters For Solar Panels,5.5kw Solar Inverter Support 5500w Solar Power R
5.5kw Solar Inverter Support 5500w Solar Power Run Without Battery 100a Mppt Charger 48v 230vac/5500w Infini Power Inverters For - Buy 5.5kw Solar Inverter,5500w Infini Power Inverters For Solar Panels,5.5kw Solar Inverter Support 5500w Solar Power Run Without Battery 100a Mppt Charger 48v...
sunmartelec.en.alibaba.com
Thank you experts!
EliteSolar
