dr00p
Dear Everyone,
I posted an hello on the forum, though while posting I found myself pouring out my last weeks about deciding what to buy as an first install for my home.
Long story short: I am in the market for some first steps in PV land. We have a shed, where 6 PV panels will be installed first. And an expasion of the roof of the shed, later on, which will make room for 2 extra panels. So 8 panels at first.
Solar panels and materials are for sale without taxes where I live, as an impulse to make people buy them.
Right now there is for example an 375W mono black panel from AEG for sale, for 44 Euros (Euro = Dollar just for convienence), which would pair nicely with an IQ8+ from Enphase. Which would clip at 290W max. And is for sale at €75,50-. And just for laughs I took 60% of that, as an reasonable amount of solar power to be expected. So €119,50
Though I was eyeing anohter panel from Aiko a bit more. An AIKO-A-MAH54Db Neostar 2s+. Which is brand new available this month, and an iteration of an previous panel. This is for sale at €114,50, for the so-called best, 460W panel. This would pair nicely with the IQ8AC or HC (ratio of 1.26 or 1.20 respectively). Which maxes out at 385W before clipping. Since the HC is available for 10 euros more at €125,- I opted for this one. So a set of this would be €239,50.
Ratio meaning that the panel is a little bigger sized, more watt power, than the inverter.
Up front, because I am already again making the mistake: The cables and metering, extra materials for the Enphase, are about a €1000,-. Enphase cables are expensive! Or seem to be anyway.
So even with 6 AEG/IQ8+ the cables and stuff make it a somewhat expensive purchase anyway. And my mind has been wondering between the two for a while now.
Reasons to like Enphase, for me as a beginner researching: The got a good name. Good warranty it seems. Low failure rate. As a plumber I don't object to go on the roof. Flexibility to play around. Free accesable info, though as I understand Enphase isn't totally DIY friendly, but far as I can see there's enough ways to not be an issue. Seemingly pretty cheap almost, for what it was (thought that can also be a giveaway that there is better stuff at the market these days).
Was so set on Enphase that I already put an 25 meter (75 foot) AWG 8 (10mm2) cable in the ground from my shed to my house where the thing is (the grid connection...), because of AC and voltage drop (I am by no means an electrician! A plumber and a life long tinkerer. But if I say something silly, here is the * up front
An against would be that a string inverter would mean higher voltages, and more harvest from your panels (sorry, my English slips away a bit).
Anyhow. Two things. I put above in an excel sheet. Double the money means about 30 percent more power. Though than I noticed that 15 AEG/IQ8+ panels would cost less than 8 Aiko/IQ8HC panel combo (1792,50 vs 1916 euros, excluding cabling and such, also no montage stuff). And would also be more power (2430W vs 1728W), and that is, I think, conservative counting (I calculated with each panel producing 60%, so 162W vs 216W for AEG or Aiko respectively).
Though I think I tackeled that for myself. Because while more panels (15 is what I have room for) is horny, about 7 of them need to go on the roof of my house, instead of the shed. And there is no room for that at this time of the year.
So, being a wee amount of panels, I am kinda thinking of the Aiko/IQ8HC combo.
Though, even though 6 panels initially, the savings is half. So that is not nothing. Even when you talk about little money.
Also reason for being torn is I have no idea what to expect between the AEG and the Aiko panels apart from the wattage. But would the Aiko panel really get that much more wattage?
One reason for it would be that is Glas-Glass, and gets (up to 10 to 30 percent) more light from reflective surfaces. But here it will be on a black roof. Both the shed as my house.
AEG actually also has a similar panel, being glas-glass and getting reflecting on the backside or so. I think an 410W model, for about 60 or 70 euros?
But apart from that, other reasons to assume a new 2024 panel would be that much better than an 2022 panel, other than the power upbring alone? So more power in shade I mean for example. How much to expect from something like that?
We had an amount of 2700 euros in mind for an install like above. Will be placing everything myself. Though switching on will be done by a electrician, after he checks everything. So but an budget of about 3000 euros for materials. Panels, Inverter, mounting, cables, etc.
I really wanted to make this short.. Just sum up some things.
Anyway, so question about above: What are your thoughts? New but bit more expensive panel? Or cheaper but saving money. And maybe install more later on. (more will be installed later on anyway, in both cases).
And I was also eying Victron, The Solar MPPT RS , is how I found out that the youtube guy is from this forum. And with the eye on grid-tied battery for home, for using at night what you stored by day, I think a Victron would be nice.
So I am in the middle of whatever, deciding where to put my money. Got about 3000 euros. Thought of 6 panels for now. They will be south oriented. What would you buy if you had to?
We would like to have about 3000kW/year in the end. That is not gonna happen with 6 panels
So but 6 panels is just a start.
Thanks for reading, Kind regards,
Maurits
Maurits
