off.the.grid
- Dec 26, 2021
- 124
Got some networking gear I need to operate, just a basic router and a couple or power over ethernet devices over solar.
Power demands will be fairly low.
12watts max, but averages less than 5 or 6 watts most of the time.
I have a small mppt charge board that charges a 2P6S battery bank of 21700 cells off a 50w solar panel.
Problem is that I want to use power over ethernet which the device only operates on a 48V supply.
I could configure the battery bank to 12S and get 50V and use a step down converter to 48V, although that presents an issue if the battery drops below 48V, so might need a boost/buck converter instead?
Any other suggestions that might work better in this application?
Biggest issue is I can't find a charge controller that will charge a 12S bank either.
I'm looking at using a boost converter board off ebay that should give me the 48V, from 25V but don't know how efficient it will be.
