Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,695
When I've checked the math (for my area of California), a heat pump and electric rates is still several times as expensive as gas heat.
When gas goes up 10x for geopolitical reasons, it may reach break-even. Similar for DIY PV systems.
I excessively over-built grid-tie PV system, so use-it-or-lose-it kWh are "free". I installed a resistive duct heater and no longer enable gas furnace.
One catch - when thermostat enabled duct heater (through a gas/electric selector switch) and duct heater signaled air handler fan to turn on, that also turned on the A/C. Had to install one more control relay to stop that.
I'm contemplating heat pump for a future install.
Maybe HPWH prior to gas water heater, hydronic loop for presently unconditioned space plus within the air handler.
