I'm planning to dial in some balancing on my server rack bank, and from what I read need to disconnect a battery and charge it full, then connect it again when the others are full so I get closer to 100% balancing starting point. I'm trying to brainstorm the best way to work on the battery, meaning, when to disconnect it. My AIO's do NOT have any AC IN connected, I use generator lockouts for grid switching when needed. Here are some ideas:
- Wait till solar is fully going, turn off breakers in the house/well so no load will exceed the solar coming it, turn off inverter to battery breakers, turn off all battery breakers, then disconnect battery in question, then turn ON inverter battery breakers then each individual battery breaker then house/well breakers can be turned on. BUT, if the inverters are actively charging the batteries is is BAD to disconnect the inverter battery breaker when 50amps is going thru it?
- Do it when there is no solar (night), shut everything down, disconnect battery in question, get everything back up and running, fully charge battery in question, but then how/when to reconnect fully charge battery to others when they are 100%?
- I do a switch to grid at some point, shut things down, get the battery disconnected, etc. BUT this is similar to #1.
- Is there some way to work on a battery while it is still connected to everything safely, meaning not disconnecting/connecting it live?
