GummiSolar
- Feb 23, 2022
- 66
Can we get a picture in the direction of arrow to see the profile of this crimp?
Nice crimps.These crimps appear to be done with the correct hardware and with the correct die / tool. I bent the cable away from the connector so you could see that the conductor is indeed copper. The cable feels very similar to the welding cable I usually use.
That is the cable wire, not the connectors. If anyone can tell me the manufacturer name of the connector it would be greatly appreciatedI have a pair of the cables from DOCAN. They are labeled as follows:
EV Cable 50.00mm2 -40°C - 125°C 1500VDC XLPE MYSUN
I think the heat would build at the top of the connection, I'm far from an expert on this just regurgitating what I've read here.I don't think that the crimp is the problem. The is obvious crimping going on. Other wise the metal would be completely round. I think the problem might be the connector was damaged higher up or the plugs was not inserted ask the way in. Look at the pictures I have attached. The us no heat damage where the crimp is!
Yes, that is what I think too.Is it possible it wasn't fully seated/locked in?
Yes, I suspected damage that wasn't easily detectable to anyone? Or the connector wasn't seated all the way. I have asked for a connector spec sheet from Apexium and Docan. Neither can provide such! This is a buyer beware situation about the connectors!I think the heat would build at the top of the connection, I'm far from an expert on this just regurgitating what I've read here.
A damaged connector could cause and the connector not fully inserted would certainly cause it.
The connector that was damaged was the top box that was connected to the inverter.The other option would be not completly pushed on. Or with the OP stacking batteries and doing a Z wire configuration (in accordance with the manual/common practice) verse using bus bars the connection just plain overheated. Thermal image of wires in this configuration are pretty stark - the first and last connection from the box to the inverter is taking current from the whole stack
To the OP - you have a stack of batteries - was this connection on the top/bottom or somewhere in the middle?
And it could just be a bad connector on the wire.
Hopefully they send him a new wire and box connection to fix the issue.
and IMO were I to do a stack of batteries I would use bus bars for all the connections to keep the current even and I would connect my uplinks between the 1&2 and 3&4 battery to keep the balance dead even. This is per the thread about paralleling batteries and the answers are not intuative but the math is.
They are not Futronics! One issue I have with Apexium and Docan is when I asked for a spec sheet or a manufacturer name they can provide nothing to me. This is now a buyer beware situation!For Seplos boxes, that's great, I assume there are full data sheets for thermal, installation, and torques specified somewhere.
Do you believe the OP's connector is futronics?
The connectors provided with the Apexium DIY boxes are not Futronics connectors.well, i've been told that basically Docan relabels the Seplos boxes, and i don't see any noticable differences at first glace in the connectors themselves
the data can be found here : https://futronics-conn.com/product/fsp-14-0-signal-core-90-right-angle-connectorip54b/
No, the connectors were provided with the Apexium diy box.OK, google image search actually did something useful for me.
Kuka Cable looks like a match. Maybe.
View attachment 222882View attachment 222884
Is it possible the Apexium connector on the box was mated with a different brand right-angle cable assembly?
These might be it.I cannot find a name or number on the connector. I think they may be provided as a completed assembly by MYSUN.
There's quite a few here: MYSUN EV Products Web Page
The Renhotec connectors only have two “stripes” on top, the OP connector has three.These might be it.
[Hot Item] Automotive Hv 200A Battery Storage 1 Pin of 8mm Plastic DC Power Right Angle Plug Connector for 50mm2 Cable
Type: Socket Terminals Material: Copper Application: Battery Pack-Motor Character: High Current Species: Plug Production Process: Injection Moldingm.made-in-china.com
I feel the same in some instances.So for anyone else following along I emailed Jenny about potentially buying boxes and wanting replacement connectors in case I make a bad crimp...
Replacement are available, from US stock.
@GummiSolar good luck in rebuilding, again I'm glad you caught the problem when you did.
Please ask for help if you are unsure on things.
If I were you I'd order replacement connectors from Docan, get a proper crimper and make some new cables. While you're at it pick up and FLIR camera so you can check all your connections and components for excess heat. My UniT has saved my ass from potential disaster once so far.
I still firmly believe this in not an Apexium or Docan issue. I've never dealt with Apexium, I wouldn't hesitate to order from Docan again, 4 smooth transactions in the past couple years.
I apologize if I sound like an ass, it's not my intention, I get frustrated seeing repeat threads like this that place blame where it shouldn't be placed.
This is a relatively inexpensive and very reassuring way to sleep at night knowing that the nearly 200A running through the connectors I crimped (rated 360A) will not burn down the house. Strongly recommended. And recheck every few months.While you're at it pick up and FLIR camera so you can check all your connections and components for excess heat.
