Install: Always connect the battery first to the SCC and then connect the panel (cover the panel first if you can) to the SCC.
Uninstall: Disconnect the panel (Best to cover up the panel with card board or blanket if you working during the day time so there will be no or little Voltage from the panel) from SCC first and then you can disconnect the battery from the SCC.
