I’m posting in hopes that someone else has already resolved this issue and can share their solution.
I have an AC200P unit in a shaded cabin in the woods. I charge it from four 175W PV panels in a 2S2P configuration. On cloudy days, the unit may not charge enough to last through that night, resulting in a low voltage shutdown. The next day, even though the PV charges the unit, there is no option for the AC inverter to turn itself back on. Hence, I need a way to expand the battery capacity to prevent a low voltage shutdown.
Has anyone found a way to expand the battery capacity of the AC200P in a way that appears seamless in the solar generator’s operation. I.e.; requires no manual cable switches/moves, will automatically charge from the PV and doesn’t void the warranty.
Thanks for the help!
